Gift Card
in The Commons
I tried buying a gift card. I can't put it in cart. Did someone else had the same problem and how did you solve it ?
How did you enter the amount? If you use the $ sign it won't work; so, try entering the amount with no $ sign. Also use decimal sign and no commas in the amount.and double check to be sure you have valid email addresses entered.
Thank you so much :) I was using the $ sign. This was the reason why I never was able to buy a gift card before :)
