CR2 Export of Genesis Clothing to Poser
UnseenArtworksUnseenArtworks Posts: 58
Hello,
I recently bought a product which is only available for Genesis, but as I'm using Poser I tried out the CR2 exporter in DAZ Studio 4.5 and it worked really fine! But there's a really strange Problem. Some parts of the clothing isn't visible in poser! In this case the "LeftLower" and "RightLower" Bones aren't visible in Poser allthough the "visible" Checkbox is activated. It's invisible in renderin too!
Has someone a solution to this Problem?
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,205
    I would say it is because it is one of the better rigged outfits that do not have the skirt following the legs!
    you prob have pose morph parameters for those parts instead.
    in PoserP12 I have and prob P9 you also have the advantage of clothifying skirts on conformed figures and the sim saves in the pz3 scene file
    only I found Poser cloth room does not really like Genesis triax weightpainting much tends to fail after about 50-100 frames in animation though I have gotten 250 on some outfits
    30 frame draped zero to posed sims for image renders fine.
  • UnseenArtworksUnseenArtworks Posts: 58
    It's not a dynamic clothing ;) But how do I get the missing parts to appear?
    never said it was
    just that you can hybrid clothify parts of rigged conformed clothing!
    if it is a skirt it will not have shin, foot bones if nicely rigged
    you pose it with morphs
    I was only offering an alternative way
    The skirt has LeftLower and RightLower bones. I think there are Morphs for posing too. But it's the bones which are hidden. Do I have to Chose other Options for CR2 Export?
    edited July 2013
    someone with that clothing might be able to tell you more
    I use Dimension3D DSON python script to import .duf myself which works far better than doing via cr2 export from studio
    I then save as cr2 to reuse.
    http://d3d.sesseler.de/index.php?software=poserpython&product=dson_loader
    You, Sir, are a hero :D Thank you so much! With this script it worked perfectly! All the Morphs are transfering propperly and every part of the model is shown! You saved my day! Thank you :)
