Looking for a Makeup Chest or Cosmetics Case
Fauvist
in The Commons
I know I've seen 3D model cases like this, but now I can't find them. Sort of like this Vampire Slayers case - except for lipstick and hairspray and all the other things a professional makeup artist would carry with them. Even if it's not made for makeup - i remember seeing something in the store that was toys or little people called Wiggles or something - that had a carrying case. I need the case to have a carrying handle, and it has to open and close.
Thanks!
There is one here but it doesn't have rooms:
https://www.daz3d.com/space-defenders-solar-mechanic-tools
I didn't see anything so maybe hang on for somebody else.
Not sure how much work you want to put in, but you could always adapt these.
https://www.daz3d.com/real-cases-1 (on sale too)
Once you sink the make up in - halfway it should be convincing.
https://www.daz3d.com/scandalous-makeup-set
And this would require adding a handle, but I've done that before too.
https://www.daz3d.com/music-and-jewelry-boxes
Same thing with this
https://www.daz3d.com/scifi-spec-ops-weapons
A couple of freebies:
http://www.sharecg.com/v/48833/browse/11/Poser/Make-Up-Case
http://trumarcar.francemi.net/props_tc.htm (scroll part way down)
ETA: Some cosmetics to fill a case with: https://www.daz3d.com/everyday-cosmetics
I believe The Truppties is the set you are describing. However, there is a door and windows on the front, so it might not do for what you have in mind. This set has a train case, which you could fill with makeup and such.
The one in the Truppties set is great. I can retexture it. Thanks everyone!
