Looking for tips to remove content without read me's
Bobvan
For example I have a lot of freebies and other content I had installed that do not have a file list or read me file. I know I can find where the main files through the library where they are installed and at times the textures through the surface tab. What I am wondering is there a way to find where ALL the files associated with a content (geometry or any extra files) without a read me file?
The way I do it is to keep all of my zips of freebie content I install, so when/if I want to uninstall something, I can follow the folder structure from the zip in one window, and go on a deleting spree in a second window.
I didn't hence my question if there is no way thats fine too since I keep my content on a 2 T external drive to use with my monster tower and notebook. Just more curious to see if there is a way...
My only other idea is hoping maybe they kept the same folder names between figures, poses, textures, etc.
Its just sometimes something lie the geometry has a name that has nothing to do with anything like I said I can find enough to remove them from being scene so its ok just in case anyone else might know
Open the CR2 or PP2 in a text editor and read the Paths that load, those should give a VERY close list of all the folders used.
I have notepad ***** I use it to edit lux files can are those files in the figure and pose locations?
Yes and Props as well.
Only works for items that HAVE poser versions... Should have mentioned that before. Sorry.
Its mainly for poser files since I have all my DS content file lists I just opened one pretty confusing reading LOL Having said that it does indicate some paths thanks alot!
rotateX xRotate
name xrot
initValue 0
hidden 0
forceLimits 0
min -100000
max 100000
trackingScale 1
keys
static 0
k 0 0
interpStyleLocked 0
rotateZ zRotate
