Problem with old content
Bobvan
Dark thorn shirt not auto fitted but actually fitted to m4 in DS 4.6 any ideas?
Post edited by Bobvan on
Bobvan
where is that shirt from ???
As indicated above Dark Thorn for M4
You mean this one - http://www.daz3d.com/brc-dark-thorn-for-m4
Yesss
ok, was not sure. Sadly I dont have it.
How odd. Ironically, when auto-fitted to Genesis there is no problem. If you have a Daz Mantis account you should file a problem ticket, if you don't or don't want to set one up, I can file a problem ticket.
I think this is already known about. I had this on older stuff, and it was caused by the new Sub Division algorithm , Catmark. You need to change it back to the old one ''Catmull-Clark ( Legacy)" and it works properly.
A polygon/vertice or two haven't been grouped properly, and because DS4 loads the entire mesh rather than just the required groups, so the result is those ungrouped polygons/vertices don't move.
If you don't want to wait on DAZ fixing it then you can use the Polygon Group Editor tool to fix the grouping, and then export a new OBJ to replace the original.
This issue has already been reported in Mantis ticket ID: 0048953. It's been assigned to JGreenlees !
How do I change it?
How do I change it?
In the Parameters pane under Sub-Division. There is a drop down list, select the Catmull-Clark one, and try it.
Where is the sub D option? I dont see it....
When the V4 MFD first came out I grabbed it and found the forearms were screwed up. I filed 3 tickets, guess what? Right, never got fixed. If the article of clothing is more then a couple of months old, and not a DAZ original, I highly doubt it will get fixed. If it is a PA item it is up to the PA to fix.
Edit found the setting did not resolve the issue
How do I change it?
Didin't work but thanks all the same
Im a bit of a retard when it comes to this tech stuff can you elaborate with more details or screen shots?
LOL I just auto fitted and it works on genesis :roll: At least it's not totally useless :smirk:
Sadly it's not that simple, I had hoped that the polygons were ungrouped, but their not, they are part of the Chest group, and while regrouping them is easy enough doing so will break every morph in the chest.
This is one of those that your going to have to wait on them fixing. unless you fancy rebuilding most of the morphs yourself. Which is probably what I'll end up doing for the friend that sent me the OBJ to check, unless DAZ can get a fix out before the middle of next month (HINT! HINT!).
Figures at the risk of sounding negative, another reason to no longer purchase DS content. The 1st forcing us to buy everything for yet another figure and 2 breaking what was working before.. I have yet to bother with genesis 2 and am in no rush to when I can produce slick renders using 4th gen and genesis along with Reality / Lux
Lindsey: how do you get your stuff to look like that? ANYTHING I autofit to genesis gets weird pitting on the underside-of-the-breast area, be the clothes for V4, M4, A3 (I have the gen3 iconic shapes), etc. and the clothes always look pointed in spots. (4.5, BTW)
Don't hold your breath.
Select the Item in the Scene Tab, open the Parameters Tab, select the Mesh Resolution Change the Sud Division to Catmull-Clark Legacy as shown here.
I dunno, I just let Autofit do it's thing and hope for the best. I'm using 4.6, but I don't know if there were any improvements with Autofit. The Autofit conversion if far from perfect though, as you can see from untextured clothing on Genesis (left) and M4. There are issues in the pants crotch, shoulders of the vest and some kinking on the vest on the lower right. Dark colors seems to hide a multitude of sins along with post work in a paint program.
There was no subdivision applied in this image, but I did subdivide the clothing and change the subdivision to Catmull-Clark (Legacy) as Jaderail suggested, but I see no improvement in these three problem areas.
Thanks I had figured it out didnt help as I said at least it works on genesis
Ah, was not sure you ever got that far. I'll send a report to DAZ about the Item. As it's still for sale it needs fixed.
Good point as I mentioned as customer its quite a turn off
I wasn't going to Stan, I've been here way too long for that, that was just me giving myself a rough date on when I might start fixing it for my friend.
This product doesn't work any better in DS3 or Poser, but instead of the distortion you get two "free floating" polygons, they use the bone welds to hold the mesh together, but that's parent-child so the chest and forearm aren't welded to each other. In DS4 every OBJ loaded by a CR2 is converted to a "single skin" mesh to try and mimic Genesis, so you now have a fully welded mesh that doesn't use bone welds, as a result a poorly grouped mesh like this will cause a distortion. The reason it autofits to Genesis is because the mesh has been regrouped to suit Genesis, and because Genesis is a different size and shape to M4, it then doesn't matter if the morphs are broken because they wont give the same results they do on M4.
You know right away if the issue is SubD, the distortions are attached to the world center, that's the place everything loads into DS at ie 0,0,0, and that's caused by bad/broken normals ie our old friend the "Black Polygon".
Apologies, this wasn't on my radar until just now.. we're on the case to get fixes sorted and updated in the store.. thanks for your patience.
I'll chime back in here when I'm told its live.
Cheers! :)
As Jack Said I am working with the artist to get the fixes for this set. As soon as I get it I will pack it and get it out to everyone. Very sorry for the delay on this but it is high on my priority list.
Thanks Jen, that's one job I can cross of my to do list.
