Missing Contents - pwGhost?
Xenomorphine
Haven't had a need to use pwGhost since upgrading from DS 4.5 to 4.6, but had an idea for something today and, the moment I go to apply it... It seems to be missing. Can open the contents panel and find the category header for it, but selecting it no longer reveals any contents.
Tried uninstalling both the product and installer, then redownloading and reinstalling both. Same result, though.
Anyone having this issue? Wondering if it's due to 4.6 incompatibility or something completely different.
The pwGhost has been updated and works well on my PC. All the pwEffect's that were updated do. Are you sure you have installed it properly?
EDIT: Here is the Update in my Content Library Tab>DAZ Studio Formats>Shaders. As you can see it now has a DS4 tag on the end.
OK, this is strange... I only really use the one way of installing it, which is through the official DS auto-installer, but after some hunting around, it's showing up in a different section to usual.
Daz Studio Formats -> My Library/My DAZ 3D Library -> Shaders
Where I usually find it is under 'Products' and then simply going to 'P'. Which, as I say, it's still under, but for some reason, the contents of it are no longer showing up under there. Just that pwGhost exists as a category. In 4.5, my default method was by going through there.
Although, having said that, before reinstalling, it wasn't showing up under 'My Library', either, so... Confused! But at least I can use it now!
I just checked and agree. The Smart Content for it is not showing properly on my system either. But I'm old school and use the Content Library Tab as my Default. Glad you found it.
the problem i have with this is it doesn't load the rim and or cloud effects, i have to manually select those.
did anyone ever make more settings for pwghost??
