Hair used with "wet skin"
5200north
I have a few good ways to make skin look wet in irau but what should I do to the hair model s, is just increasing the glossiness adequate? I was going to experiment with different settings tomorrow but I thought maybe someone had some advice before I start.
Post edited by 5200north on
I don't think that would be enough. Think how wet hair looks and how it actually differs from dry hair, the way it clumps and sticks to the skin; you can't fake that just with surface settings. There are a few wet-hair models in the shop, I would suggest using them and, if you want to portray the same character with both wet and dry hair, just make sure the base colors match up.
https://www.daz3d.com/warrior-wet-hair-for-genesis-3-male-s
https://www.daz3d.com/summer-wet-hair-for-genesis-3-female-s
https://www.daz3d.com/drop-wet-hair-for-genesis-3-female-s
I'm still primarily using Gen3 so these are the three I have.
Yes, as Uthgard said, just make sure you use close to the same hair color and you'll be fine.
VWD works quite nice for creating wet hair looks; but it requires quite a bit of practice too.
use hair styles that are pulled back or combed back like a bun or other very neat styles. So it you started with a behive hairdo you'd endup with a bun (or similar style without that bun others that hug the head) when it was wet. Then change the glossiness enough to make it look wet.
Also:
https://www.daz3d.com/short-wet-hair-for-genesis-8-male-s-and-female-s
And this hair also comes with the wet skin geoshell to go with it.
Laurie
Over at Rosity is a free hair by zoro_d which was put up in June of this year called Side Swept ROse Hair (Yes, the O in ROse is a cap). It has a wet preset as well as a wet material setting. I'm not sure it looks totally convincing, but it may be a good starting point for you.
I wonder if some hairs would allow some to create the effect w dforce, as thats what the basic effect of wet hair is, a lot heavier + gravity.
https://www.daz3d.com/dforce-master-hair-simulation-presets-for-dforce-cloth-engine
Sorry, Virtual World Dynamics. The pay alternative to dforce.
