Adding to Cart…
Ho Wow! Thanks for these
I'm curious - can you now open LAMH on the fur that is loaded to the character? Or does it still crash?
YEs It crash again I have just tried
But Your presets are working correctly
I precise: LAMH can be open but DAZStudio crash when i click on some options
How much RAM do you have in your system, if I may ask?
EDIT: just checked the log file you attached and it says you have 32GB, which should be more thna sufficient.
If you just open the basic view of LAMH, can you then save the fur to obj, or does it crash then, too?
EDIT of EDIT: while looking through the log file, I stumbled across a warning message about nested folders:
Do you have a runtime within a runtime folder? That might cause problems. Though I don't know if it is in any way related to the crash you experience. The log file itself doesn't have any message in regards to the crash, unfortunately.
Rebonjour
If you just open the basic view of LAMH, can you then save the fur to obj, or does it crash then, too? YES
Do you have a runtime within a runtime folder? That might cause problems I JUST CHECK I HAVE ONLY ONE RUNTIME IN MY DAZSTUDIO FOLDER AND IT IS INSIDE MY LIBRARY FOLDER
I remember that before version 4,10 LAMH was working and when i bought it i have use to obj option with success
