Frustation about LAMH
2»
  • MartialMartial Posts: 431
    Ho Wow! Thanks for these
  • BeeMKayBeeMKay Posts: 7,019
    I'm curious - can you now open LAMH on the fur that is loaded to the character? Or does it still crash?
    YEs It crash again  I have  just tried
    But Your presets are working correctly
    622 x 607 - 232K
    I precise: LAMH can be open but DAZStudio crash when i click on some options
    edited August 2018
    How much RAM do you have in your system, if I may ask?
    EDIT: just checked the log file you attached and it says you have 32GB, which should be more thna sufficient.
    If you just open the basic view of LAMH, can you then save the fur to obj, or does it crash then, too?
    EDIT of EDIT: while looking through the log file, I stumbled across a warning message about nested folders:
    2018-08-13 04:57:25.828 WARNING: general\dzcontentmgr.cpp(1820): Nested directory encountered
    while adding a content folder: D:/DAZStudio4 64 bits/My Library : D:/DAZStudio4 64 bits
    Do you have a runtime within a runtime folder? That might cause problems. Though I don't know if it is in any way related to the crash you experience. The log file itself doesn't have any message in regards to the crash, unfortunately.
    Post edited by BeeMKay on
    Rebonjour
    If you just open the basic view of LAMH, can you then save the fur to obj, or does it crash then, too? YES
    Do you have a runtime within a runtime folder? That might cause problems I JUST CHECK I HAVE ONLY ONE RUNTIME IN MY DAZSTUDIO FOLDER AND IT IS INSIDE MY LIBRARY FOLDER
    I remember that before version 4,10 LAMH was working and when i bought it i have use to obj option with success
