Emotiguy made emissive -- problems
davesodaveso Posts: 7,908
edited August 2018 in The Commons
here is a pic of emotiguy ... i have him in a scene..wanted to use him as light source, so you can see what has happened...to bright overall, weashing his teeth away ..also, I had to make sunglasses totally opague to allow them to look like sunglasses.
I'm a rookie on this emissive stuff ... tried adjusting a few things, but mainly I would like a few details to show on emotiguy.
Post edited by Chohole on
  • BeeMKayBeeMKay Posts: 7,019
    Make sure you have the skin map plugged in in both, the base colour and the emission colour. Also, don't go much above 70.000 cd/cm^2 lumiance, as otherwise, the light will be too bright. It's kind of like a light bulb - the more energy it emitts, the brighter it gets, and while you can look at the glow while it's low, when you go full strength, you get blinded.
  • davesodaveso Posts: 7,908
    thanks..I've been slowly turning down the light, but now its not bright enough and still not getting anty detai in the emoiguy face... ah ..it may be the skin map thing though..i will try that
  • Peter WadePeter Wade Posts: 1,675
    I've fiddled with emissive textures a bit. I'm not an expert in this but I have a theory. In real life anything that is bright enough to illuminate a scene is likely to come out as a featureless blob in a photograph and would probably dazzle you if you looked straight at it. I think it may something you have to accept with a realistic rendering system.
  • ChezjuanChezjuan Posts: 541
    Once you get the emissive to show details, you could put small light behind Emotiguy to give the effect of the light coming from him. Something like a small spotlight or something from the Iray Ghostlight kit, set bright enough to illuminate the section of the scenes you need him to light.
    You could just create a sphere and make it a ghostlight, with the light pointong outward (or use one of the sphere ghostlights from the ghostlight kits), and place the Emotiguy body inside of it. Use scaling so you'll get the right shape, and make the emissive colour something very close to the emotiguy colour. Then you can turn down the Emotiguy emission itself until it still 'glows' but you don't miss too many of the details.
    so basically not bother to make the guy emissive but use alternate lighting.
    I'd use a combination. The surface does look different when it is emissive, after all.
    Do you intend to use the bloom filter?
    bloom filter .. never heard of that. like i said, I'm a rookie wit this emissive stuff.
  • nonesuch00nonesuch00 Posts: 18,795
    Turn the emmisive way down to like 1 or 2 watts.
    The bloom filter is in the render settings under "Filters", and causes a "glow" effect on emissive surfaces, or surfaces that reflect light. The default value is pretty strong, but you can get some cool effects using it. It will affect render times and isn't always advisable, though.
  • KitsumoKitsumo Posts: 1,222
    edited August 2018
    daz3d emotiguyTry this. It's the Emotiguy with a geometry shell outside it, and the shell is an Iray matte surface that emits light. There is some reflection off the glasses back onto his face. For some reason it doesn't work if the environment (hdri) is turned off. I'll take a look and see if I can find out why that's happening.
    1280 x 720 - 804K
    duf
    duf
    emot emissive.duf
    343K
    Post edited by Kitsumo on
