Obj import problem [Solved]
Hello
Obj import CINEMA 4D settings open [Ambient Occlusion] rendering engine appears Genesis 8 Male eyes turn black?
Ask how to solve the problem? Thank you!
Attach file
Post edited by liulang03 on
Hello
Attach file
I'm not familiar with C4D, but I wonder if it is seeing the transparent layer over the eyes, representing eye moisture, as an occluding surface? You might check the settings for that surface - remember that OBJ supports only a very limited range of material settings, so it's likely that you will need to extensively rework them for rendering in another application.
thank you for your help
After the adjustment, the problem is solved.
