Last version of Bryce to have the merge function
I am trying to get back into Brycing after a couple of years of medical problems and can't seem to remember the last version to have the merge function. Thinking it was B5. Can anyone help?
Thanks:coolsmile:
Are you talking about the ablity to merge 2 scene files. You can do that in all versions up to , and including, the latest which is Bryce 7
Alternatively what you can do is load the scene you want to take things from, select the things you want in your other scene, copy (ctrl + c) them. And then, without closing that instance of Bryce, use file and open the scene you want those copied things in and then just used paste (ctrl + V). The pasted things will fall into the same space as they were copied from so, unlike the object library which just brings in at world origin + half objects total height.
Got it. Thanks!
