DAZ export aniamtion broken
Hello, I was currently using DAZ 4.10
I tried to export some animation and its broken.
using both fbx and dae
It tried the same pose, it was working, but now don't
  • Basically every animation I try to export is broken.
  • What are you exporting to?
    cinema 4d
  • Have you tried soem of the other FBX versions? Does C4d have various options for import?
  • paodan56paodan56 Posts: 3
    edited August 2018
    I tried to import back to DAZ, still broken.
    try to import in Maya same things.
    Post edited by paodan56 on
  • I meant other options in the exporter. I seem to recall that those can make quite a diffrence, though I don't have anything with a robust importer to test on.
  • Cinema 4D usually imports DAZ FBX fine, but what generation character are you using ? have no idea how it behaves with G3/G8, I think I tried with G3 without any big hickups though, have you got it working before with older versions of DAZ ? or is this the first time you try ?
    You can specify the version of FBX when you export from DAZ, try 2011 or 2012 versions, these usually works best.
