Installing content
Please help;
I purchased Victoria 7 and i have two install options:
1.  Manual
2.  Or let the install manager do it.
I choose manual...so i download a zip file...and i unzip/install V 7 to:      C:\Users\Public\Documents\My DAZ 3D Library\People\Genesis 3 Female
But after i open Daz and try to load her it says that files are missing....
Am i installing to the wrong location?...what am i doing wrong?...
Normally i do use the install manager and everything installs correctly....but i wanted to try a manual install to see if it also works for me that way...but as you can see i have no idea what i am doing...but i do want to learn how to install content manually...i feel that it is a skill that i am missing.
Some pointers would be appreciated.
  • It looks as if you have taken the whole of the zip and simply dumped it in the Genesis 3 Female folder. If you want to install manually you have to take the contents of the folder named Content and merge them into your existing content directory (the folder that appears under Daz Studio Formats in the Content Library, it probably isn't called "Content").
