Postgre SQL
sheedee3Dsheedee3D Posts: 214
edited August 2018 in New Users
Please help;
I just installed Daz Studio 4.10 Pro...but i am getting these messages:
In my install manager i have the option to install 2 versions...but i dont know which of the two i have to install:
(i have windows 10 64 bit by the way)
1. PostgreSQL CMS (Win 64 bit)
2. PostgreSQL CMS from Valentina CMS conversion
Post edited by Chohole on
    If you still have the Valentina one then you need option 2    If it is a completely new install  then you need option 1.
  • You need 1 regardless, that's the actual database engine. If you haev an older installation, using Valentina and with a populated database, then "installing" 2 actually runs a conversion application that will make a postgreSQL database with the same contents as the Valentina database (if it can).
