Where are the morph i just installed?
Hello,
Ive Bought the Genesis evolution bundle and installed it. But ive search around and cant find it. Ive checked the shaping panel and its not there neither on the parameters panel. Where could it be? Sorry for my English. Its still the same stuff like Before i installed it. Oh and i used install manager so you know.
Regards
Post edited by jonas_haag9 on
They don't appear as an Evolution group, and there are no icons for loading them, they are in the Parameters pane.
The above are in Actor > Universal > Real World in my Parameters pane
If you go to the Parameters pane, select 'All' at the top, and type in Fingers, for example, you can find them that way. There may be an easier way, but I don't use the Shaping tab, so I don't know.
Thank you for answering. Ive checked that also, but it looks exactly like it did Before i installed them.. And fitness etc doesnt show "nor do fingers when i search by all" Something isnt right here, i have genesis starter Essentials wich is required... I was thinking about buying Jason and jasmin bundle but not until this i solved... Regards
If you used the DIM, the files should be in the correct place. Did you install Genesis Starter Essentials using DIM as well?
The reason I ask, is because the DIM installs to a folder called My DAZ 3D Library by default (unless you change it yourself), so if you installed the other content into My Library (the previous default location) then DS will not see them.
if DIM means Daz install manager then Yes, ive used it for all installations...
If you are installing to the default path for the DIM, the content goes into C:/Users/Public/Documents/My DAZ 3D Library
by default. Check in the Content Directory Manager inside DAZ Studio, that you have that listed as both a DAZ Studio Formats folder, and a Poser Formats folder as well.
You also need to have a Genesis figure loaded and selected in the Scene pane to see the morphs for Genesis (NOT Genesis 2).
That worked, thanks alot JimmyC! So now when i buy new morphs and install them with DIM it should work fine... Have a nice day Regards
