Genesis 2 Platform
What is the new Genesis 2 Platform? I'm having some problems understanding whether I even have the Genesis 2 Platform on my computer. I believe I downloaded it however, I can't see where it is in my Daz3d Pro 4.6 program. Can someone with more information than me help me to understand where I can located the new platform on my computer? What makes it different than what I already had? Thanks loads.
Post edited by LJWM on
Are you installing through DIM or extracting manually.
Manually. DIM doesn't work right. It doesn't install all the parts and I end up having to figure out what parts didn't get installed and trying to install them anyway. So it's manually.
I have no idea why the DIM does not work for you. I have installed nearly 2,000 items with it, and it has always installed the correct folders to the correct places, but that is another story.
The 'Genesis 2 Platform' is another way of describing the new Genesis figure, called Genesis 2. It is an improvement on the original Genesis figure, and it was added to everyone's Product Library when it was released. If you go to your My Account area, and look for Product Library, you should find the file called 'Genesis 2 Female Starter Essentials'
When you have installed it, you will find the new figure in the same place as the original Genesis.
Careful how you phrase that, it isn't in the same place ("Genesis" folder), it's in a parallel folder in the People folder ("Genesis 2 Female" folder). A lot of people have been worried that they can't safely put G2 in their existing content, they don't realise there are no overlapping files so the two figures can safely co-exist.
Well it has never worked for me. I've even called support and they had to help me find out what files were missing. Believe me the installer is a frustrating mess and doesn't work.
So what you're saying is there is no way for me to know whether I have the Genesis 2 figure because it looks just like the old figure, right?
Now this helps a little but I looked in my DAZ Library folders and found People -->Genesis-->characters...but there is no Genesis 2 at all. I downloaded it twice and it stated that the original was there but I still downloaded it. However, I can't find the files on my system. My search in DAZ3d Pro doesn't work anymore and I'm thinking maybe I should just uninstalled the whole program and reinstall but I can't find the uninstall for the DAZ3d program.
I don't think you have Genesis2 installed at all, or if you have, it is not correctly installed.
The reason I said it installs to the same place, is because if you look for Genesis, and you have Genesis 2 installed, you will clearly see it like the image posted below.
Inside the ZIP folder for my Genesis 2, there is a folder called 'Content'. If you installed this yourself, you MUST open the Content folder, and install the folders inside that to your DAZ Studio Library. If you have simply dropped the Content folder into your My Library folder, then DAZ Studio will not see it.
If that is the case, then you need to move all of the folders inside the folder called Content, and move them up one level, so that they are directly under the My Library folder (or whatever you call your DS Library folder)
If you want to uninstall DS, and start again, there is no need to find an uninstaller, when you reinstall any version of DAZ Studio, it automatically removes any previous version (program only, not content)
Thank you so much Jimmy. This should really help. I'm going to reinstall Daz3d Pro 4.6 then see if it pulls up my Genesis 2. If this doesn't I'm going to follow your instructions to the letter and see if I can make this work. I'll let you know if it works or if I really mess up everything. : )
It works. Thanks so much, it took a while to get it all in the right folders and in the right places but it works now so I'm happy.
Now can someone please tell me why none of my content shows up in my Smart Content Folder? It did before I downloaded 4.6 now it only shows up on my Daz Studio Format folders.
Smart Content relies on the CMS (Content Management Service) to display it's content. CMS runs as a process, and not only Smart Content, but Products and Categories need it to be running, as well as the search function in the Content Library pane.
In Windows, check the Task manager to see if it is running. You can also go to Start > All Programs > DAZ 3D, and restart it from there.
See if that helps.
Thank you so much Jimmy. I used your instructions from another thread. I have not check it yet but I sure hoping it works.
Hoping you can help me out, Jimmy:)
I tried unzipping the Genesis Starter Essentials G2Female to the Studio/My library folder - it did not show up in Smart Content and I eventually traced the Genesis 2 Base Feale .duf file to My Library/Content/People/Genesis 2 Female . When I try to open from there, I get an error that the /data/DAZ 3D/Genesis 2/Female/Genesis2Female.dsf is missing and it opens a robotic figure.
This missing .dsf file is included with the .zip file, along with many other files that seem to need to go into whatever /data folder is being referred to - but where would that be located? In other words... what comes before /data?
Or have I got the whole setup screwed:(
Cheers
You can NOT have a CONTENT folder in the My Library folder. That is Nested content folders as far as DAZ Studio goes. Open the CONTENT folder and COPY all in it. Then go up ONE folder and PASTE into the My Library folder.
All DIM zips have a CONTENT folder at top, that CAN not be added to the MY Library or My DAZ 3D Library Folders as it is a Valid folder still used in DS3. Un-ZIP all DIM zips OR OPEN them and only MOVE the folders inside the Content folder to your My Library folder.
So is that why in some freebees the stuff is in a folder called CONTENT instead of My Library? They're using an older version of Daz?
ALL DIM zips use the Content folder format. It is needed for the DIM to install properly when used to install. I myself see no reason for the extra folder to be used, I just live with it. But then I also Love the DIM so do not Hand install very often any more.
Ya, that is one of those things I find hilarious. It's been "my library" since Studio 4 came out yet all content is still packed in a "content" folder. This is certainly not at all confusing.
I've been rebuilding a minor working folder; no way I am downloading 100gig of content to install on a temp comp. So I have been installing all of it to my library even though I am using the poser format. I do it all manually, I have no need of CMS or DIM.
I just open the zip, check the contents, cut everything out of the content folder and paste it in to the my library folder. Everything drops right in to place. A rare occurrence for me when I used installers. When I used installers it was no telling where my content was going to turn up. From what I have read about DIM it's not much better. I got in the habit of installing to a dummy folder, then moving it to my library folder. It was the only way I could be sure my content was all there and in the right place.
But then I have always considered CMS and DIM giving a man a fish. ;-)
Actually the DIM works very well if you understand it. It really just comes down to getting the paths set up in both programs.
I agree, the DIM is the best thing that ever happened to installing content.
It is absolutely painless, and I would not be without it.
Yep, I use DIM for DS3A, DS4.6, Carrara 6 Pro, Bryce 7.1 and Poser 9. All my content goes right where I told it to. Nice bit of kit.
FWIW, I consider the problem more to do with DAZ constantly changing the default content folder name — the important fact is that that's the name of the content folder, not that the folder name is and must always be "Content" or "My Library" or whatever.
It's a tricky situation, really, related IMHO to how people learn to use computers. I've taught a lot of people who've never used computers before, and a lot who have, but aren't familiar with the program we're using, and one of the most important things for them to learn is "there is no ONE TRUE WAY to do anything". Settings can be changed, defaults are only that, and doing something by mouse or by keyboard shortcut are not different*. Once that's settled in the little grey cells, the rest starts to make sense with less effort.
* Unless the programmers did something horribly worng...
Thanks so much, Jaderrail - that got it working :-)
Not in Smart Content, but it does show up and load from the Content Library.
Must say that at first try, Gen2 does look pretty good.
I once tried using DIM - it listed just about everything I'd ever installed, which would have eaten up a couple of months' worth of broadband allowance, so I only selected the most important stuff. Off it went, downloading something like five files at a time. Then, as each file got to 90% downloaded, it came up with a simple "Download failed" - no reason given. Had to kill it before it used up all my broadband allowance and haven't touched it since.
I Agree with most here in some way, at the point things are in MOST programs now, not just DAZ Studio and DIM, some basic knowledge on how your PC and it's OS functions is required now days. Took me much heartache before I got my Ron's Brushes installed properly in GIMP, but was a breeze in PS CS6. Everyone should try to at least learn the Basic's.
Hello,
I can see the Poses of Genesis 2 Female and I can load the "Genesis 2 Base Female"-Body. But if I try to load anything else (any of the Poses,...) I get the error "An error occured while reading the file, see the log file for more details".
Does someone have the same problem? I don't know what to do and I cannot attach the logfile to this post (no Textfile, no zip).
Thank you very much!
Hi,
sorry for the late reply: have broken my lower arm :(
Here's the log.
Thank's a lot!
+++++++++++++++ DAZ Studio 4.6.0.18 starting +++++++++++++++++
Platform bits: 64
Qt Version: 4.8.4
Running on Windows 7, Build 7601, Service Pack 1
CPU Information:
CPU String: GenuineIntel
CPU Brand String: Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
Cache Line Size = 64
L2 Associativity = 6
Cache Size = 256
Stepping ID = 5
Model = 10
Family = 6
Extended model = 1
CLFLUSH cache line size = 64
Supported CPU Features:
SSE3 New Instructions
MONITOR/MWAIT
CPL Qualified Debug Store
Thermal Monitor 2
x87 FPU On Chip
Virtual-8086 Mode Enhancement
Debugging Extensions
Page Size Extensions
Time Stamp Counter
RDMSR and WRMSR Support
Physical Address Extensions
Machine Check Exception
CMPXCHG8B Instruction
APIC On Chip
SYSENTER and SYSEXIT
Memory Type Range Registers
PTE Global Bit
Machine Check Architecture
Conditional Move/Compare Instruction
Page Attribute Table
Page Size Extension
CFLUSH Extension
Debug Store
Thermal Monitor and Clock Ctrl
MMX Technology
FXSAVE/FXRSTOR
SSE Extensions
SSE2 Extensions
Self Snoop
Hyper-threading Technology
Thermal Monitor
Pend. Brk. EN.
Physical Memory:
Total: 7.9 GB (8580620288)
Avail: 5.5 GB (5962874880)
Virtual Memory:
Total: 7.9 TB (8796092891136)
Avail: 7.9 TB (8795888037888)
Current Memory Usage: 30%
Current DateTime:
Loc: Fr 20. Sep 21:42:08 2013
UTC: Fr 20. Sep 19:42:08 2013
Temp Data:
Location = C:/Users/Andreas Liebal/AppData/Roaming/DAZ 3D/Studio4/temp
Disk Total: 232.7 GB (249952202752)
Disk Avail: 124.9 GB (134126751744)
Locale: de_DE
No translator found.
Reading style definition C:/Program Files/DAZ 3D/DAZStudio4/resources/style/Main Street.style
Creating managers
Reading help index
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/DAZ Studio/DAZStudioHelp.dsx
Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/inlinehelp.dsx
Scanning import folders
Scanning content folders
Using GLEW 1.9.0
Supported OpenGL extensions:
GL_AMD_multi_draw_indirect
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_blend_func_extended
GL_ARB_clear_buffer_object
GL_ARB_color_buffer_float
GL_ARB_compatibility
GL_ARB_compressed_texture_pixel_storage
GL_ARB_conservative_depth
GL_ARB_compute_shader
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_indirect
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_instanced
GL_ARB_ES2_compatibility
GL_ARB_ES3_compatibility
GL_ARB_explicit_attrib_location
GL_ARB_explicit_uniform_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_layer_viewport
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_no_attachments
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_invalidate_subdata
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_draw_indirect
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_robust_buffer_access_behavior
GL_ARB_robustness
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_separate_shader_objects
GL_ARB_shader_atomic_counters
GL_ARB_shader_bit_encoding
GL_ARB_shader_image_load_store
GL_ARB_shader_image_size
GL_ARB_shader_objects
GL_ARB_shader_precision
GL_ARB_shader_storage_buffer_object
GL_ARB_shader_subroutine
GL_ARB_shader_texture_lod
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_include
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_stencil_texturing
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_bptc
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_gather
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_levels
GL_ARB_texture_query_lod
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample
GL_ARB_texture_swizzle
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_transform_feedback_instanced
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_attrib_binding
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_S3_s3tc
GL_EXT_texture_env_add
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array
GL_EXT_Cg_shader
GL_EXT_depth_bounds_test
GL_EXT_direct_state_access : NOT INITIALIZED
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXTX_framebuffer_mixed_formats : NOT INITIALIZED
GL_EXT_framebuffer_multisample_blit_scaled
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_shader_objects
GL_EXT_separate_specular_color
GL_EXT_shader_image_load_store
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_format_BGRA8888 : NOT INITIALIZED
GL_EXT_texture_integer
GL_EXT_texture_lod : NOT INITIALIZED
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_shared_exponent
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_storage : NOT INITIALIZED
GL_EXT_texture_swizzle
GL_EXT_texture_type_2_10_10_10_REV : NOT INITIALIZED
GL_EXT_timer_query
GL_EXT_transform_feedback2 : NOT INITIALIZED
GL_EXT_vertex_array
GL_EXT_vertex_array_bgra
GL_EXT_vertex_attrib_64bit
GL_EXT_import_sync_object : NOT INITIALIZED
GL_IBM_rasterpos_clip
GL_IBM_texture_mirrored_repeat
GL_KHR_debug
GL_KTX_buffer_region
GL_NV_alpha_test : NOT INITIALIZED
GL_NV_blend_minmax : NOT INITIALIZED
GL_NV_blend_square
GL_NV_complex_primitives : NOT INITIALIZED
GL_NV_compute_program5 : NOT INITIALIZED
GL_NV_conditional_render
GL_NV_copy_depth_to_color
GL_NV_copy_image
GL_NV_depth_buffer_float
GL_NV_depth_clamp
GL_NV_draw_texture : NOT INITIALIZED
GL_NV_ES1_1_compatibility : NOT INITIALIZED
GL_NV_explicit_multisample
GL_NV_fbo_color_attachments : NOT INITIALIZED
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_fragdepth : NOT INITIALIZED
GL_NV_fragment_program
GL_NV_fragment_program_option
GL_NV_fragment_program2
GL_NV_framebuffer_multisample_coverage
GL_NV_geometry_shader4
GL_NV_gpu_program4
GL_NV_gpu_program4_1 : NOT INITIALIZED
GL_NV_gpu_program5
GL_NV_gpu_program_fp64
GL_NV_gpu_shader5
GL_NV_half_float : NOT INITIALIZED
GL_NV_light_max_exponent
GL_NV_multisample_coverage
GL_NV_multisample_filter_hint
GL_NV_occlusion_query
GL_NV_packed_depth_stencil
GL_NV_parameter_buffer_object
GL_NV_parameter_buffer_object2
GL_NV_path_rendering
GL_NV_pixel_data_range
GL_NV_point_sprite
GL_NV_primitive_restart
GL_NV_register_combiners
GL_NV_register_combiners2
GL_NV_shader_atomic_counters : NOT INITIALIZED
GL_NV_shader_atomic_float
GL_NV_shader_buffer_load
GL_NV_shader_storage_buffer_object : NOT INITIALIZED
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4
GL_NV_texture_expand_normal
GL_NV_texture_lod_clamp : NOT INITIALIZED
GL_NV_texture_multisample
GL_NV_texture_rectangle
GL_NV_texture_shader
GL_NV_texture_shader2
GL_NV_texture_shader3
GL_NV_transform_feedback
GL_NV_transform_feedback2
GL_NV_vertex_array_range
GL_NV_vertex_array_range2
GL_NV_vertex_attrib_integer_64bit
GL_NV_vertex_buffer_unified_memory
GL_NV_vertex_program
GL_NV_vertex_program1_1
GL_NV_vertex_program2
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_NVX_conditional_render : NOT INITIALIZED
GL_NVX_gpu_memory_info
GL_OES_compressed_paletted_texture
GL_OES_depth24 : NOT INITIALIZED
GL_OES_depth32 : NOT INITIALIZED
GL_OES_depth_texture : NOT INITIALIZED
GL_OES_element_index_uint : NOT INITIALIZED
GL_OES_fbo_render_mipmap : NOT INITIALIZED
GL_OES_get_program_binary : NOT INITIALIZED
GL_OES_mapbuffer : NOT INITIALIZED
GL_OES_packed_depth_stencil : NOT INITIALIZED
GL_OES_point_size_array : NOT INITIALIZED
GL_OES_point_sprite : NOT INITIALIZED
GL_OES_rgb8_rgba8 : NOT INITIALIZED
GL_OES_read_format
GL_OES_standard_derivatives : NOT INITIALIZED
GL_OES_texture_3D : NOT INITIALIZED
GL_OES_texture_float : NOT INITIALIZED
GL_OES_texture_float_linear : NOT INITIALIZED
GL_OES_texture_half_float : NOT INITIALIZED
GL_OES_texture_half_float_linear : NOT INITIALIZED
GL_OES_texture_npot : NOT INITIALIZED
GL_OES_vertex_array_object : NOT INITIALIZED
GL_OES_vertex_half_float : NOT INITIALIZED
GL_SGIS_generate_mipmap
GL_SGIS_texture_lod
GL_SGIX_depth_texture
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
WGL_EXT_swap_control : NOT INITIALIZED
WGL_ARB_buffer_region
WGL_ARB_create_context
WGL_ARB_create_context_profile
WGL_ARB_create_context_robustness
WGL_ARB_extensions_string
WGL_ARB_make_current_read
WGL_ARB_multisample
WGL_ARB_pbuffer
WGL_ARB_pixel_format
WGL_ARB_pixel_format_float
WGL_ARB_render_texture
WGL_ATI_pixel_format_float
WGL_EXT_create_context_es_profile
WGL_EXT_create_context_es2_profile
WGL_EXT_extensions_string
WGL_EXT_framebuffer_sRGB
WGL_EXT_pixel_format_packed_float
WGL_EXT_swap_control_tear
WGL_NVX_DX_interop
WGL_NV_DX_interop
WGL_NV_DX_interop2
WGL_NV_float_buffer
WGL_NV_multisample_coverage
WGL_NV_render_depth_texture
WGL_NV_render_texture_rectangle
: NOT INITIALIZED
OpenGL features for current hardware:
OpenGL provider: NVIDIA Corporation
OpenGL renderer: GeForce GTX 460/PCIe/SSE2
OpenGL version: 4.3.0
Maximum number of lights: 8
Number of auxiliary buffers: 4
Number of texture units: 4
Depth buffer bit resolution: 24
Maximum OpenGL texture size: 16384 x 16384
Current OpenGL Texture Quality Setting: Good Performance
RGBA color bitplane resolutions: 8 8 8 0
GLSL version: 4.30 NVIDIA via Cg compiler
Shadow mapping supported
VBO supported
*** Scene Cleared ***
Loading plug-ins:
aniMate2.dll
dazscriptide.dll
dz3dconnexion.dll
dz3dmouse.dll
dzalignace.dll
dzassetiofilters.dll
dzautofit.dll
dzautoriggerbasic.dll
dzautoshaderbakeractions.dll
dzbrycebridge.dll
dzbvh.dll
dzcolladax.dll
dzcomponents.dll
dzcontentdbeditor.dll
dzcontentlibrarypane.dll
dzcr2exporter.dll
dzcustomizedlg.dll
dzdelightrenderer.dll
dzdformeditor.dll
dzeasyloader.dll
dzexpexporter.dll
dzfbxexporter.dll
dzfbximporter.dll
dzfiguresetup.dll
dzhexagonbridge.dll
dzimageio.dll
dzjointeditor.dll
dzlayerededitor.dll
dzlayerfilter.dll
dzmanualshaderbaker.dll
dzmaptransfer.dll
dzmorphfollower.dll
dzmorphloader.dll
dzmorphloaderpro.dll
dzobjexporter.dll
dzoptitexclothbasic.dll
dzpolygongroupeditortool.dll
dzprimitives.dll
dzpropertyeditor.dll
dzpuppeteer.dll
dzpz3importer.dll
dzrenderedit.dll
dzrenderlibrary.dll
dzrslshadercompiler.dll
dzsavefilters.dll
dzscriptedrenderer.dll
dzscriptedsteps.dll
dzshaderbaker.dll
dzshaderbuilder.dll
dzshadereditor.dll
dzshadermixerbase.dll
dzshadermixergui.dll
dzsmartcontentpane.dll
dzspotrendertool.dll
dztextureatlas.dll
dztransferutility.dll
dzu3dexporter.dll
dzweightmapbrush.dll
dzwinvideo.dll
sdk_sceneinfopane.dll
dzpowerpose.dll
WARNING: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
Total class factories: 1218
WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
3D mouse support library could not be loaded.
Creating interface
Successfully created OpenGL viewport for Viewport1.
Successfully created OpenGL viewport for Viewport2.
Successfully created OpenGL viewport for Viewport3.
Successfully created OpenGL viewport for Viewport4.
Executing startup script...
Started in: C:/Program Files/DAZ 3D/DAZStudio4
DAZ Studio Started
Creating Pixel Buffer
Pixel buffer - Width: 1024 Height: 1024
Compiling OpenGL Shader...
Fragment Shader:
Fragment Shader compiled successfully.
Linking Shader:
Fragment info
0(29) : warning C7050: "_rgb" might be used before being initialized
Shader Program successfully linked.
Error reading file, see log for more details.
