texturing DForce clothing and other outfits
TSasha Smith
I was wondering what is the best way to texture DForce clothing and other outfits that are DS only. I think ZBrush for example has some paint on 3d object ability, but I do not know how to bring the outfit to Zbrush.
What are my options to create textures for DForce clothing and other outfits for DS figures?
I use Photoshop to texture my clothing. Makes no difference if they are standard or deforce.
Some products come with texture templates right? You can use those, or go to surfaces tab, go to diffuse map, and click on it. Than you select browse...
With an image editor / painter, like photoshop, affinity photo or gimp you can change the texture.
If you use the Geometry Editor in D|S to add dForce surfaces, and their original textures get wiped out, simply copy the material from the original parts of the object and paste to the newly created dForce surface.
Otherwise, texturing a dForced item you've made is like any other item. dForce is only going on in D|S and doesn't carry over to other apps, except maybe their material/surfaces if you've already created them.
