1st Import from obj files
Neilr
Ok I gave up trying to get the DAZ Studio Bridge to work so I just imported some stuff in as obj files. Ultimately I want to get good at using both. The retuexturing of the supersiut was not as bad as I expected. I also had to fix a few things on the character but again, no biggie. My Castle Project which is only partially done imported well to bryce, all the texturing I do seems to be compatable with bryce, this should please chohole.
Next I want ot try some of those 3D pictures...starting with this scene.
Well tried my first analglyph.... I think I should move the camera back a bit and then reduce the field of view...but not sure any opinions on this?
Refining my use of gimp I sued the same left and right renders to make this version of the anaglyph.
My second test in gimp I Moved the cameras mot so far apart and reduced the rotation about half.
ON the third version I moved the camera rotaion a bit more than on the previous pic. Also on these last two I moved the camera back and narrowed the FOV.
