help with EE sky box please
Chohole
This discussion was created from comments split from: 360 Panoramic (Cube Map/Sky Box).
Chohole
Hi,
I recently bought 'easy environments desert' but I can't seem to get the skybox to show up when I render. Is there something I need to do in the 'render settings' under 'environment' or something? Forgive my ignorance. Any help would be much appreciated :D
Thanks
Splitting this post of into it's own thread.
Which set is that? If it's one of the older sets, you will need to do some set-up as they were made for 3delight and I suspect you are rendering in Iray http://flipmode3d.com/converting-3delight-skies-to-iray/
