Daz Studio closes whenever I try to load this one scene!
I'm working on a set of images for an art trade. I created the scene and actually rendered the first image, but after that, I restarted my computer, and when I opened Daz again, I did some stuff in a different scene before going back to change the figure poses for the second render. However, when I tried to open the scene, it started to load, but partway through the process, Daz studio closed without even an error message. I have tried again at least five or six times since then, with the same result each time, whether I open it from the Scenes folder in my Content Library tab, use File>Open Recent, or even use my file explorer to try opening Daz straight to that scene. Every time I do this, it closes at the same moment in the loading process. I've tried opening several other scenes, and all of them open just fine. Can anyone tell me what might be going wrong or how to fix it?
EDIT: I took a screenshot of the progress bar it always closes on. It closes when the bar in the attached image reaches 50% completion.
You may want to check the log just after the crash, it might give a clue as to what's causing the problem...
