How to completely wipe out Studio and content for a clean install
Digital Cats Media
I want to re-install a clean copy of 4.6 and it's content. I uninstalled the previous version and installed 4.6, and Genesis through Install manager. When I try to load Genesis it cannot find the .dsf file , it's pointing in the wrong directory trying to load it from where it was in the old install. For the life of me I can't figure out how to do a clean install so this doesn't happen. I have done this for my Poser installation and content and it went smoothly without a problem but for some reason the fresh install of Studio still points to the wrong folder.
Anyone have a suggestion?
You need to set DS to see the NEW content folder. The DIM installs to a Different folder than the Base folder DS auto makes. Use the Content Directory Manager to Add the proper Folder to both the DAZ Studio Formats Path and The Poser Formats Path. Here is mine below. You also need to use the Prefs to set the Load scene to load the Genesis.duf and not the dsf.
