Genesis, Genesis 2, Genesis 3, Genesis 8; Basic Software Files
epeaches
The basic Genesis software files to load to get Genesis to work properly are:
Files to download for Daz Studio 4
Genesis Starter Essentials
Genesis Female Starter Essentials?
Genesis Male Starter Essentials?
Genesis Generation X
Genesis Generation X Female Starter Essentials?
Genesis Generation X Male Starter Essentials?
Genesis 2 Starter Essentials
Genesis 2 Female Starter Essentials
Genesis 2 Male Starter Essentials
Genesis 3 Starter Essentials
Genesis 3 Female Starter Essentials
Genesis 3 Male Starter Essentials
Genesis 8 Starter Essentials
Genesis 8 Female Starter Essentials
Genesis 8 Male Starter Essentials
Search and download all Genesis Files I guess to be sure the program works right, I guess. Are those the basic files to install???
I am not aware of any Genesis Generaton X Starter files.
Here are the Starter files loaded in my Library:
I did load Genesis 8 Starter files but the Genesis 8 Models are still not loading or showing up after installation. Genesis 6 files are not working also. I believe they may need to create
Genesis 4 Starter Essentials
Genesis 5 Starter Essentials
Genesis 6 Starter Essentials
Genesis 7 Starter Essentials
Some models show up and some do not show up and that is very disappointing.
There are no Genesis 4, 5, 6, 7. Daz went from Genesis 3 to Genesis 8 (for historical reasons.
How did you load the files? The Content Directory Manager in Studio needs to have the correct path. If you have a folder called "Content" at the top level, you need to remove it.
If you use Daz Install Manager (DIM), the installation path in DIM must match the content path in Studio. See image for Studio content path example.
