Imported model texture issue
Hi, any suggestions?
I've imported a U-boat figure from PoserPro 11 with parented props (Cage, Gun and periscopes).
Unfortunatly one of the props is black (Cage), the textures are all in the same location and settings for the props are all the same.
Despite this one of them is not working, If all the props failed in the same manner I wouldnt be as confused.
As the settings & related files are the same the props should all fail or work the same way?
The models render okay in Poser.
  • Doube-check the Ambience settings, and make sure all maps are loaded, including bump, specular, environment, or normal maps. They don't always translate properly, even if they are set the same.
    Also compare the actual color settings between Poser and D|S for each texture. If Poser used Nodes to manipulate the color even further, that would do it.
