OpenCL missing with DS 4.11
Since installing DAZ Studio 4.11 (64bit BETA), I can't get dForce to work. I just get an error message saying that it can't find an Open CL 1.2 device. I'm using two GeForce GTX 1080 Ti GPUs; I would have thought they would be up to date enough for DS.
Has any one else come across this error? Does any one know how to fix it?
See attached images.
  • IceCrMnIceCrMn Posts: 2,320
    Several of us are having that problem.
    have a look at the beta test thread over here https://www.daz3d.com/forums/discussion/265581/daz-studio-pro-beta-version-4-11-0-171#latest
    You will probably want to submit a bug along with your log so it can be added to the ones already in the system.
  • IsaacNewtonIsaacNewton Posts: 1,300
    Thanks for the reply. Bug report now submitted.
    Have you checked your graphics card driver version? That's just as vital to OpenCL compatibility as having the most recent 10-series NVidia cards. Note that Windows Update has a known habit of replacing perfectly good NVidia drivers with lower spec versions that don't have the same OpenCL or OpenGL capabilities — some of us consider it a good idea to check which driver version D|S thinks your system is running after every Update Tuesday.
    Updating the drivers to version 24.21.13.9836 did the trick.
    Thanks.
