Making glows "behave" when lighting adjacent surface?
TurnerTurner Posts: 116
Hi all,
I'm having an issue where a glowing surface is not properly illuminating an adjacent object. Basically, a glowing lens of a light is not properly illuminating the inside edge of the opening.
I have most settings turned up pretty high. Any advice appreciated...
  • ManStanManStan Posts: 0
    Glow channel in the texture or anything glows? What are your render settings?
  • TurnerTurner Posts: 116
    Hi ManStan,
    Glow channel.
    Settings attached.
    244 x 918 - 87K
    If the lens is a single mesh; a separate part, and simple, you might try anything glows. You can use the glow channel of a shader to light a scene, but it's touchy and iffy.
    But your render settings for doing it are right.
    Tried it - not working. I think it has something to do with the fact that the faces I'm expecting to light are perpendicular to the emitter... is that possible?
  • wcwilcoxwcwilcox Posts: 0
    Tried it - not working. I think it has something to do with the fact that the faces I’m expecting to light are perpendicular to the emitter… is that possible?
    I think that be the answer.
    Image 2 was done with 2.2 gamma setting.
    640 x 480 - 51K
    640 x 480 - 37K
    Hm.... are those sitting on a white surface?
    The background was the default gray setting.
    The image below was done on a white background same.
    640 x 480 - 67K
  • CarltonMartinCarltonMartin Posts: 147
    Try increasing photon count, maybe. That helps me sometimes when I have odd corners in lighting.
    Yeah, tried that - it was certainly cleaner, but the surfaces still weren't illuminated from the adjacent glowing / anything glows object.
    thanks-
    Andrew
