Change render dimension
Dear,
I'm trying to render my scene with a big resolution.
I just see this options in render settings:
But when I change the values they return to default values and only the raw values are changed:
How can I change de values in order to render and create a TIF/PNG image or how can I export a raw file ?
Thanks a lot, Xavi
  • BeeMKayBeeMKay Posts: 7,019
    That's the camera dimensions? Or where are you trying to change the size?
    You'd usually go to the Render Settings, and change the size there; it only works if you have a different ratio than "viewport" selected, as that will always give you the pixel size of the viewport.
    The Render SEttings are also where you can change the type of image.
    Check out http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/chapters/rendering/start
    or the "Rendering" tutorials in the video section https://www.daz3d.com/help/help-daz-3d-video-tutorials
  • xavieratorxavierator Posts: 161
    edited July 2018
    I just find one way to increase the render resolution, see the attached image:
    I would like to change resolution for my needs, but I can't change the W and H pixels for my self, only choose some of the the presets.
    It will take a lot of time, at this moment 15 minutes and 0 % rendered crying
    I have a computer with this features, is enough ?
    Intel Core i3-4010U 1.70GHz
    16GB RAM
    W7 64 bits
    Thanks, Xavi
    398 x 587 - 36K
    Post edited by xavierator on
  • Richard HaseltineRichard Haseltine Posts: 108,585
    Make sure you turn off Constrain Proportions before entering size values.
    Dear,
    Resolved, there is a custom preset to enter free values:
    Thanks, Xavi
    224 x 146 - 6K
