Trippy bug
Just downloaded DAZ on a new pc and this weird thing occurs . The background is black and everything leaves trails of itself when i move the viewport . Also the grid is black with white lines , which leaves trails also.
  • Richard HaseltineRichard Haseltine Posts: 108,568
    That's usually down to the video driver being used. What video card/GPU are you using? It should be listed in the dialogue launched from Help>Troubleshooting
  • zibin12zibin12 Posts: 6
    i have 1080 i7-7700
    i dont understand whats wrong
    432 x 464 - 19K
    Sorry, I can't read the screenshot - try copying-and-pasting it as text.
    Current OpenGL Version: 4.4.0 - Build 22.20.16.4691
    OpenGL Provider: Intel
    Hardware: Intel(R) HD Graphics 630
    Features:
    MultiTexturing Supported
    Shadow Map Supported
    Hardware Antialiasing Supported
    OpenGL Shading Language Supported
    Pixel Buffer Supported
    Pixel Buffer Size Not Enabled
    Maximum Number of Lights 8
    Number of Texture Units 8
    Maximum Texture Size 16384 x 16384
    DS is not using your nVidia card then, it's using the Intel GPU (in the CPU I guess). You should be able to switch by connecting the monitor to the nVidia card (if you have two connectors) or by a settings in the control panel (if it's just one connector).
    aww yea i fixed it , but now its all gray instead of white wireframe , can i fix that also? :)
    1134 x 983 - 68K
    Are you sure it isn't meant to be like that? It is a monster, after all. If it had skin the image wouldn't be allowed on the forum.
    oh yea its gray but i cant see wireframe floor
    Click the lined button in the top corner (the option menu) and make sure Display grid is on. It may also be on but invisible due to the background colour.
    tywm thats it for me
