Can't convert the fur on the Big Cat 2 Sabretooth to iRay
nonesuch00
I can't convert the fur on the Big Cat 2 Sabretooth to iRay using the !Iray Uber Base.duf preset that usually works on converting 3DL Surfacers to iRay. Hints?
Thanks.
is it a LAMH curve?
No, it is the Big Cat 2 Sabretooth is it comes supplied with the Big Cat 2 Pro Bundle. The Surfaces are separated into two parts - fur surfaces in one part and the skin, teeth, mouth, eyes, nose and other surfaces in the other part. It is the fur surfaces that won't convert to iRay, the other part surfaces did convert to iRay.
