Single PNG for multiple presets with the same name? SOLVED
Lissa_xyzLissa_xyz Posts: 6,116
Hopefully I can explain this well enough.
What I have:
File.ds
File.duf
In DS, I get 2 icons with the same PNG, one for the duf, and one for the ds.
What I want is only 1 icon for both types. See image for example.
How can I get this to work, or does this only work if the 2 files are for separate programs?
Post edited by Lissa_xyz on
  • BejaymacBejaymac Posts: 1,945
    Has to be a Poser format file, a DS format file and a PNG thumbnail, and all 3 files need to be in a Poser Runtime directory, before DS will load the DS file instead of the Poser file.
    Ah well crap. lol Thanks
  • fixmypcmikefixmypcmike Posts: 19,692
    I haven't tried it with .duf's, but you can have both a .ds and .dsa with one Poser-format file, and DS2 will use the .ds while DS3 uses the .dsa.
    I don't have poser so I don't make poser mats since I can't test it. I was just hoping this would work with multiple DS files also. I went ahead and used it to my advantage though, created an identical PNG and used the icon to label right on it DSA and DUF. Thanks for the responses though, guys. =)
