Genesis 2 Starter Essentials missing from DIM?
AllenArtAllenArt Posts: 7,175
Anyone else? The rest of them are there, but not Genesis 2's....
Laurie
  • IceDragonArtIceDragonArt Posts: 12,833
    Mine are still in DIM under installed files
  • fastbike1fastbike1 Posts: 4,079
    Mine are in DIM
    I have no idea why mine aren't showing up, but thanks guys :)
    Laurie
  • DiomedeDiomede Posts: 15,393
    Could you have inadvertently hit the wrong buttons and hidden them?  Kind of a reach but you might try the menu to show hidden?  Good luck.
    edited July 2018
    No, that's the first thing I checked ;) I mean, it's not a huge deal...I can still install them manually.
    Laurie
    Post edited by AllenArt on
  • TaozTaoz Posts: 10,271
    edited July 2018
    I just checked mine, there seem to be something wrong with these - I have a "Genesis 2 Male Starter Essentials" under Ready to Install, but also one under Installed, with a different name. Both the Male and the Female Starter files were actually updated not long ago (2018-03-30), these are the one under Installed. What I suspect happened is that they changed the names and intented to delete the old files during the update, but something went wrong so they (or at least the Male version) weren't deleted.
    Hm, I did the above check offline, now I tried to go online to see if anything had changed, and now the old "Genesis 2 Male Starter Essentials" under Ready to Install has mysteriously disappeared. Nothing seem to have changed under Installed.
    It's just a few days ago I were online with DIM, so it looks like something has happened since which has removed the old "Genesis 2 Male Starter Essentials".
    351 x 465 - 28K
    Post edited by Taoz on
