Carrara Challenge 41: The Super, Legendary, Epic Render Challenge!
168101112
  • VIArtsVIArts Posts: 1,523
    The lights you see on the ship are just from ths glwa channel. They don't give off any actual lightf.  is there a way to turn them into lights?
    edited July 2018
    Using Indirect Light will treat the glow channel as a light source, butthe glow needs to be really intense for any kind of range. You could also use an Anything Glows light. you choose the ship model as the light source, and then in the controls for the light you can set it so that only areas with a glowing shader emit the light.
  • DiomedeDiomede Posts: 15,388
    edited July 2018
    Captain Sunburn - Splitting Hairs
    Rather than use Philemo's hair conversion plugin, I used the multipass volume primitive pass and did an overlay in PSE.
    2000 x 2667 - 2M
    Captain Sunscreen and Tomato Boy in Spike Trap 5b gmic filter toon filter.png
    2000 x 2667 - 4M
    Captain Sunscreen and Tomato Boy in Spike Trap 5b gmic filter toon filter_VolumePrimitives1.png
    2000 x 2667 - 481K
    Captain Sunscreen and Tomato Boy in Spike Trap 5b gmic filter toon filter_PostEffect1.png
    2000 x 2667 - 3M
    Post edited by Diomede on
  • VyusurVyusur Posts: 2,235
    edited July 2018
    I was very impressed by Bunyip's tutorial. It stimulated me to create this image with System 46 and my custom morphing on Genesis 3 Female. I used metaballs as terrain and a hair piece with fire texture on it converted with Philemo plugin.
    Carrara native render, no postwork.
    1165 x 701 - 688K
    1151 x 712 - 423K
    800 x 670 - 390K
    1000 x 1300 - 1M
    Post edited by Vyusur on
    Wow, that is very powerful.
    edited July 2018
    Nice! What tutorial is that?
    Post edited by VIArts on
    Vyusur: That is spectacular!
    Diomede: A really "super" fun scene!
  • StezzaStezza Posts: 8,732
    +1 on that
    @Vyusur that is epically awesome yes
    Thank you, Ted!
    Evilproducer, Stezza, thank you very much!
  • Persona Non GrataPersona Non Grata Posts: 1,365
    edited March 2021
    Post edited by Persona Non Grata on
    edited March 2021
    1920 x 1080 - 769K
    @Selina - very clever use of the gradient.  He'd better pay more attention to his surroundings.  Well done.
    Selina, thank you so much!
    ]Oh lordy, my bergs shaders take milions of years to render and my setttigs are not Best this time. Good thing i'm patient.
    just sayin'. lol
  • Bunyip02Bunyip02 Posts: 9,226
    Excellent work Vyusur, very glad my little spiel was helpful/of use !!!!
    Very nice !!!!
    Selina said:
    Finally tweaked the shader for the hairy terrain to look more like a slippery muddy embankment (hairy trees follow this shader) and added a subtle water plain for interest with a Velouté gradient alpha mask to fade around edges and keep the mystery of what lies deep in the forest...
    Epic 5
    Attached is my .car screen shot showing objects in scene...
    Selina
    Love the glow effect !!!
    edited March 2021
    Thank you, Bunyip, for your comments.
  • HeadwaxHeadwax Posts: 10,385
    Vyusur said:
    I called it “Bone-Tree Planet”. I used hair on my metaball trees instead of leaves. The terrain is also metaball creation converted to vertex object with some geometry cleaning. Procedural shaders were used on both. Carrara native render.
    just super sci fi superb!
    I've been busy today, but I have managed to get a bit more done with my scene. I'm in the process of building a temple/palace. I will have to take a couple pillars and break them apart to sell the ruins aspect. I still need to work on the roof. After that, I will build some more ruins, but I may build them on little terrain islands so that I can duplicate and rotate them and place them wherever it is aesthetically pleasing, I also want to paint certain areas of the main terrain to suggest old stone pavers and such pealing out from the (eventual) jungle floor. I think I will also attempt a crumbling reflecting pool. It is ambitious, so we'll see how far I get before the challenge ends.
    Oh, I built the steps out of a gradient image map applied to a terrain with the terrace filter, height filter and erosion filter. I then modified the Tapui Terrain texture that came with Carrara to get the even more weathered look.
    EP that's very impressive - the little version looks like a real photo
    Stezza said:
    My WiP for Georgio scene..
    thanks Stezza, superb blow by blow how to do..!
    be back tomorrow and check out everyone's work - looks gob smackling!
    Bunyip, thank you very much for the comment. Looking forward for more interesting tutorials from you.
    Andrew, many thanks!
  • AlbertoAlberto Posts: 1,456
    Undine, legendary character.
    First, I created a terrain with a crater
    Next, copied the terrain and convert in vertex modeler, added thickness, deleted the bottom (as is selected after the thickness operation), then selected the bottom edge and filled the polygon and tesselate it. Now, it's usable for a Fluid simulation as a solid.
    Next, the hair on the terrain. It will be the grass:
    Some simple trees are set in the original terrain with surface replicator.
    The distribution map:
    The scene with a Fluid domain, a cube was used as the mass fluid.
    Added Genesis 2 Belle character as the Undine. Then ran the fluid simulation. Next, used long hair for Undine.
    Added too some acuatic plants, fog, Volumetric cloud (more fog) and 3 lights: sun light (used a simple realistic sky),  LightX Dome and Area lights.
    Last steps were applying shaders, adjusting lights and rendering with GI (the rendering is in process)
    1920 x 1040 - 348K
    1920 x 1040 - 344K
    1920 x 1040 - 642K
    256 x 256 - 4K
    1920 x 1040 - 372K
    1920 x 1040 - 521K
    edited March 2021
    edited July 2018
    In this case I used metaballs for pie creation. Every object in this scene was modeled and textured in Carrara. Attached are screenshots. Octane plugin render, no postwork.
    1307 x 1000 - 2M
    977 x 757 - 136K
    818 x 877 - 197K
    812 x 723 - 178K
    1386 x 726 - 288K
    745 x 518 - 280K
    928 x 888 - 372K
    1202 x 695 - 949K
    712 x 465 - 95K
    707 x 589 - 167K
    918 x 556 - 161K
    815 x 521 - 625K
    edited July 2018
    Two renders. The first s awful. Too bright and purply for night. Second is a bit better.
    2731 x 2048 - 554K
    1365 x 1024 - 100K
