Primitive Color and image Rotation
Hi all
I am using a primitive and added an image to it to act as a logo on a wall. But it's blue and looks like it's swopped horizontally and verically.
If i swop the actual plane then the image/lettering is still wrong. Any ideas?
  • Richard HaseltineRichard Haseltine Posts: 108,624
    Try switching the axis option (positive to negative or vice versa) when crating the primitive. Other than that, whata re you surface settings? Are you rendering in Iray or 3Delight?
  • macleanmaclean Posts: 2,438
    You can flip the image by setting Horizontal Offset to -1 (in Iray or 3Delight). But do as Richard says and check the axis because it shouldn't be flipped in the first place.
  • plarffplarff Posts: 282
    Hi All
    Ill let you know what the surface settings are as soon as i am home.... Rendering in IRay for most part. But is this something i have to apply on the primitive or part of my Render settings?
    On the primitive for both. For Richard's tip, you have to do it when you create the primitive. For mine, go to the Surface pane and select the primitive's material.
    edited July 2018
    Ok ive done as you said, cant find the material option?
    561 x 535 - 57K
    Post edited by plarff on
    Default is the material.
    I am sorry but i still dont understand what to change???
    I solved the issue... Primitives dont like png with transparent background.
