Glitch in Cycle aniblocks?
Basically, there is always a hiccup or glitch in my figure when a cycling aniblock like a walk cycle is repeated. The first cycle works fine, but then the character slips around a big in the transition to the next cycle. Happens no matter how I adjust the transition slider. Any ideas on why this happens or a fix?
I have tried the reorient buttons but they don't seem to illiiminate the bumps. My current work around is putting the figure into a new group and then keyframing at the group level to adjust for this bump...but this is a pain.
The solution: the figure has to be at 100%. If the scale is adjusted than the aniblock will jolt their position between cycles.
