Adding to Cart…
So even after reading through all this, I can't seem to get the shaders to not render gray. Can anyone help or is this to old?
I beleve so
Where did you move the Nvidia folder to? Because it really sounds like you are missing the actual vmaterials.
\Documents\DAZ 3D\Studio\My Library\data\!MDL\mdl\nvidia\vMaterials
as the text file in the freebie said to
Should be \Documents\DAZ 3D\Studio\My Library\data\!MDL\nvidia\vMaterials
You have an extra mdl in there.
Now it's rendering the correct color but nothing else.
No pattern or anything.
Ok, I got it now, you have to apply the subsurface base shader first.
Well what ever I did is not working on any others than the Carpet - Circles.
Probably should have tested that more before I said something.
You have to have the file path EXACTLY Documents\DAZ 3D\Studio\My Library\data\!MDL nothing more or less.
Yes, that's the folder you have to put the nvidia folder into.
I've added the "vMaterials" folder to !MDL\nvidia\ then set mdl base folder to it.
the question is: where those shaders should appear? I can't see them in the shader and I can't find anything added to the shader mixer
shareg links seem dead.. is this still available?
OP updated the shaders to version 1.4 of vMaterials.
Here's the link to the newest version.
Hello, Thank you for all the information on these presets. I do have a problem seeing them though. I did steps One and Three with no issue. I thought I did step Two but Im not sure if I under stood it at all. I took the folder "vMaterials" and placed it in my daz library under "shader presets-iray-vMaterials". When I open daz and go to the shader presets tab I see the vMaterials folders but none of the shaders show up. So where did I go wrong?
Thank you so much for your help.
Joseph
Hey, jorr. No, you did not get that step correct. Move the vMaterials from where you placed it under shader presets-iray-vMaterials in your My DAZ Library to C:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\nvidia. That should give you C:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\nvidia\vMaterials. Please note that, as the instructions stated, the foregoing file paths will only be valid on your PC if you installed DAZ Studio to the default location of C:\Program Files. If you installed it somewhere else, you will need to know where or look for DAZ3D\DAZStudio4\\shaders\iray\nvidia\ folders elsewhere, and place the vMaterials folder there.
It looks like the ShareCG links no longer work. I'm posting in the OP post as well.
All sharecg links fail
ok, here is the Main Link
http://www.sharecg.com/pf/full_uploads.php?pf_user_name=mcdlabs
and here for the 1.5
http://www.sharecg.com/v/91698/gallery/21/DAZ-Studio/vMaterials-1.5-AEC-IRay-Shaders
Thanks Twilight...very helpful.
I'm hoping you can help with this...I'm having (what I hope is) a stupid problem:
...but I don't see the new materials anywhere is Daz. I assume they are supposed to be somewhere in Actors, Wardrobe & Props > Presets > Shaders, but I can't find them anywhere. I've tried restarting the app and looking in/refreshing all of the folders. Any thoughts if I'm looking in the wrong place, or have done something wrong someplace?
You'll find them in your Content Library pane under Shader Presets > vMaterials.
...and there they are! Thanks Tim!
When I downloaded the material library from Nvidia I was not prompted to install the MDL Exchange. I checked under directory path "C:\ProgramData\NVIDIA Corporation" and this folder exists but there is NO "mdl" subfolder.
I was able to download MDL Exchange installer from Nvidia at this link at the bottom of the page.
https://www.nvidia.com/en-us/design-visualization/technologies/material-definition-language/
Sorry but these links are not working. AND YES I logged into ShareCG with my account.
Wow... Broken links. Instructions that have been re-written because the initial did not work. This thread is a complete time waster and needs to be vaporized.
OOPS...sorry but I must have mispoken. I did download http://www.sharecg.com/v/91698/gallery/21/DAZ-Studio/vMaterials-1.5-AEC-IRay-Shaders and they installed fine and I was able to test a few of them. They look great....
Just thought I would leave this here: The vMaterials do not work in Daz Studio 4.11 Beta as of January 2019, but still work fine in 4.10. No idea why.
