Hair not fitting G8F character
Ted Berlin
I just purchased the Wild Wind Hair for G8F https://www.daz3d.com/wild-wind-hair-for-genesis-8-females and it is not fitting correctly on a younger G8F I have. Is this something I am stuck with now and forced to look for another hair or can it be manually adjusted to fit properly? Any suggestions would be appreciated.
I do adjust almost every hair item I use with fair fit morphs for my characters done with a few DFormers and adding a Smoothing Modifier.
You can adjust the overall volume or try to fix some individual strands or bangs to move them around or scale them.
Here are a few things you can do with hair and DFormers:
Don't fit the hair to the figure just parent it to the head and you can use the translate dials to move it into position and the scale dials to get it to fit, it sometimes helps to make it a bit smaller than the head and then add a smoothing modifier and put collision as the figure.
I will have to try this, thanks scorpio and Syrus
You might find some help taking a look at this Daz 3D tutorial on using the various shaping tools to help with posing hair.
