What happen?
Can someone tell me what happen to her cleavage, and how to fix it?
Heres the lighting I'm using
https://www.renderosity.com/mod/freestuff/sc-hdri-lights-for-daz-studio/76735
  • Ted BerlinTed Berlin Posts: 106
    Looks to be a shadow to me. have you tried repositioning the light angles?
  • scottalan1016scottalan1016 Posts: 2
    edited July 2018
    ok
    Post edited by scottalan1016 on
    edited July 2018
    As far as I can tell the lights can not be moved.  I did however put a spot light on her chest it made the area darker.
  • Cris PalominoCris Palomino Posts: 12,506
    Try removing the lights and see how it renders. You can also move the figure back to see if it still renders the same way.
  • FishtalesFishtales Posts: 6,212
    They are HDRI lights so it is a map in the Studio dome which can be turned and will move the lights. Is the camera light turned off as that will affect the lighting too. Also make sure the figure is far enough away from the camera to stop distortion.
