Transfer Utility Issues
Hellish-AbaddonHellish-Abaddon Posts: 0
I'm trying to use the transfer utility on a pair of shorts, problem is the shorts import on the ground (see attachment)
When I position the shorts on Genesis and then use the transfer utility the shorts automatically fit to Genesis but they go back to the import position on the floor.
Anyone know what the problem is here?
All settings in Transfer Utility are default and I use the "Pants-Tight" option.
  • Richard HaseltineRichard Haseltine Posts: 109,256
    It looks as if you are using the wrong preset to import - possibly the 3DS preset, since it appears to be flipping y and z axes. If you can, try changing to a preset that works. If not, line the trousers up, hide everything else, export as OBJ and then reimport (making sure you use the same preset each way).
  • Hellish-AbaddonHellish-Abaddon Posts: 0
    edited July 2013
    Yep, you nailed it with the preset. I was importing as OBJ and it wasn't working. I imported now as FBX and that works fine.
    Thanks
    Edit: I should read things more carefully lol
    Post edited by Hellish-Abaddon on
