stuff
1356719
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,423
    edited July 2013
    forest superior tests
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 4M
    edited November 2025
    very Gory video
    1920 x 1080 - 2M
    BTW the reason I did that video was soley because I was midway between watching my 5 disc set of Game of Thrones season 1 & disc 3 was defective not playing past a point on either of 2 DVD players, my laptop or desktop.
    Anyway I returned the set to the store and the replacements played fine so now I need to buy the next 2 seasons!
    but
    looking at the costumes and scenery
    I realized I have EVERYTHING needed to recreate it in my runtime
    the Barbarian is Dothraki through and through (I am certain I have the hair somewhere too!)
    any of my countless bits or armour and chainmail could suit the Southern kingdom
    certain I have the all Notherner's clothes and NightWatch stuff too!
    which makes me think, a lot of PA's might be G.of T. fans!
    edited July 2013
    http://youtu.be/vAAwwWmKzzU
    just screencaps from my iClone video
    1009 x 1057 - 169K
    485 x 939 - 102K
    433 x 897 - 93K
    913 x 1053 - 155K
    1920 x 1080 - 333K
    because this video is gone I will use this post to upload some images for other posts
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 3M
    1920 x 1080 - 3M
    1920 x 1080 - 3M
    1920 x 1080 - 2M
    1920 x 1080 - 3M
    1920 x 1080 - 3M
    edited July 2013
    Khal Drogo and Daenerys, a video I am rendering
    2000 x 2000 - 3M
    2000 x 2000 - 3M
    2000 x 2000 - 3M
    edited July 2013
    http://youtu.be/7TqFLqsA5Uo
    not very happy with it, a bit uncanny valley
    1920 x 1080 - 1M
    another removed video, more image storage
    1920 x 1080 - 3M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 3M
    1920 x 1080 - 3M
    1920 x 1080 - 3M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    edited August 2013
    playing with Skull cove, planing a story
    http://www.youtube.com/watch?v=8ywlJ02WmGw
    will prob use iClone,
    (as in video)
    my results in Carrara pretty much sucked, needs a lot of shader work
    Poser nice but VERY slow
    Daz studio even more so unless I lose the lighting and water shader
    1600 x 900 - 305K
    1920 x 1080 - 3M
    1920 x 1080 - 3M
    1920 x 1080 - 2M
  • NovicaNovica Posts: 23,925
    Wendy, would you mind sharing the water settings for that third image? (they might all be the same) Your water looks FANTASTIC. :)
    is just default Poser load for that scene
    the second Daz studio default
    the first is Fisty's water shader with some tweaking,
    the last Carrara with a digital carver's ocean shader
    my pics reversed from order I posted
    more image uploads
    1920 x 1080 - 3M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 3M
    1920 x 1080 - 2M
    1920 x 1080 - 3M
    1920 x 1080 - 3M
    playing with dream home in iClone 5
    can get whole thing in with furniture after some drastic map reduction
    doing a video,
    some shots
    (yes I leave unseen bits out at times)
    1920 x 1080 - 4M
    1920 x 1080 - 3M
    1920 x 1080 - 2M
    have to make a few compromises on quality to do video
    1920 x 1080 - 3M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
  • bighbigh Posts: 8,147
    now this looks interesting !
    TY Bigh,
    edited August 2013
    doing a bit of kitbashing
    1920 x 1080 - 3M
    1920 x 1080 - 654K
    very nice - looks great
    edited September 2013
    some enchanted comparisons
    DS hour and half, iClone a few seconds
    1920 x 1080 - 5M
    1920 x 1920 - 5M
    added water to iClone same speed
    Carrara IBL one hour
    1920 x 1080 - 3M
    1920 x 1080 - 5M
    Carrara no IBL minute and a half
    lightdome 100 lights i hour
    1920 x 1080 - 3M
    1920 x 1080 - 3M
  • SpyroRueSpyroRue Posts: 5,020
    Brilliant Render Wendy that recent one totally blown me away. Great stuff!! :cheese:
    THX Spyro
  • none01ohonenone01ohone Posts: 862
    Nice, I like the kitbashing pics. Notice your using iclone, does that mean it can import Daz stuff?
    more images to replace removed content
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 3M
    1920 x 1080 - 3M
    1920 x 1080 - 2M
    1920 x 1080 - 3M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    Thanks for the reply Wendy. I've only recently installed the freebie version of iclone4 but haven't got around to trying it out. That 3DXchange looks amazing, being able to import loads of formats like sketchup and then export as obj's. Wanted to convert some 3ds to obj's and tried to via blender but the textures didn't convert. Will look at this later, as I'm pretty wiped out this month with the Daz sale.
    Sorry couldn't play you vid, my player just locks up. But that's probably because I don't use media player.
    Thanks again.
    need to use quicktime a Quicktime virtual reality mov
    and iClone 4 ok for most prop imports, to get E forest in break it down into bits, too big one go, texture sizes may need to be reduced too for 4 (32bit only), I use iC5 64bit beta.
    For Daz figures (people) you really need iC5 iC4 can only import them as animated props if at all.
    mind you I used it for years and if I wanted Daz people in there as it has animated textures I just rendered one in studio with an alpha/opacity outline video and stuck it on a plane as an avi texture, casts shadows.
    At the moment I don't think I'll be doing a lot with iclone4, I've barely got a fingernail grip on DS.
    Anyway, now that I'm registered on their site, maybe an offer to good to resist may come down the pipe. If thats the case then I may end up getting iclone5 later on.
    Thanks for taking the time out to explain, appreciated.
    I tend to aviod Quicktime as I've had problems in the past, ie perpetual pop up nag screens and the way it was embeded. Ended up installing realalternative on my old XP pc just go get rid of it. My Firefox browser keeps asking to add/update Quicktime player plugin. -NNNOOOO.
    I may have to install it later, but for now I'm poking it away with a stick.. Shooo.
    edited November 2013
    500 x 800 - 7M
    there are Angels on this forum
    250 x 300 - 7M
