select all emission surfaces
WendyLuvsCatz
is there a way to select all the surfaces in a scene with emission?
You can rightclick on one and select a matching diffuse value or a particular texture map, I would love to isolate all the emission surfaces at once for a number of reasons, turning them all off one many would no doubt find handy, or increasing the value
for me it is simply so I can add emission in Octane.
iray shaders translate over to Octane render pretty well unlike 3 Delight but not the emission.
at least not in OrDs 2 maybe 3 reads them but am not updating my plugin for just that if it even exists.
The only solution I know of for this, and a great all around tool, is V3Digitimes Iray Light Manager Pro
Not if they have different values (there's an option in the right-click menu to select all surfaces with a value of..., which then lets you pick any parameter, but I don't think you can select "non-black". It should be scriptable.
At a quick test thiss eems to work, except I had to deselect and select the object to refresh the surface list. Extending it to work on multiple selected object is left as an exercise for the reader.
I guess I save this as a dsa, thank you, not quite sure how to use it but will give it a whirl
Yes, save as a .dsa file and double-click to run (or, if it works, make it a Custom Action by right-click so you can get it from the Scripts menu). It should select all surfaces with a non-black Emission Colour, though in my case (using a test prop) I had to deselect and reselect the item to see the surfaces list change.
manual
"expand all" -"select all" object in scene (scene tab)
go to "SURFACE" tab
"select all" again
on parameters top
type "emiss" on search, make your changes
now type "lumi" on search, made your changes
good to know too, for those scenes that actually let me do it
sadly lots of scenes lately freeze up selecting all surfaces as I often do to remove all bump and displacemet maps so they will fit on my card
sadly again with Richard's script I hit the same bug where I cannot select all the surfaces of all the objects in my scenes
I used to be able to but the last few Betas of DS I cannot
DS just freezes
wondering if Octane actually is the cause of my bug as seen on video,
that blue mouse pointer circle spins for hours and hours if I let it have to kill DS in Task manager
Well, my script as it stands works on only one selected item. If you just want to zero everything then the suggestion from cm152335 is the simplest way to do it, mine was selecting all surfaces with active emission (well, non-black colour) for further adjustment.
the real issue sadly is Octane render DS
I think it causes too many issues including the ability to select every surface in the first place
thanks for the help, its just the price I have to pay for choosing a nonstandard integrated render plugin.
at least iray materials work much better than 3Delight ones with it, that is something and of course HD morphs work with it, not grouped instances well not the 2.25 version at least.
