Zero Displacement Limits
Richard HaseltineRichard Haseltine Posts: 109,356
edited March 2015 in Freebies
https://www.dropbox.com/s/xnqjh4o8nfk9h23/ZeroDisplacementLimits.zip?dl=0
A simple DAZ Studio script to zero the Minimum and Maximum values for surfaces that have Displacement Strength set to 0, to avoid weird effects when using the SSS Shader for DAZ Studio 4.5 and later.
  • SzarkSzark Posts: 10,634
    That will come in handy eventually Richard thank you.
  • DarleymikeyDarleymikey Posts: 8
    Thank you, Richard.
  • KeryaKerya Posts: 10,943
    Sorry - I am always pointing people here - and forgot to say thank you ...
    THANK YOU!
    Again, thanks for the help.
  • Richard HaseltineRichard Haseltine Posts: 109,356
    You're all welcome.
  • Eustace ScrubbEustace Scrubb Posts: 2,730
    Is there a way to script a reset of all non-hidden values in a shader to their defaults in one swell foop-- er, fell swoop?
    Should be possible - using my script above as a starting point, something like
    if ( materialList.length > 0 ) {
     beginUndo();
     var dispControl, maxControl, minControl;
     // Go through the materials looking for the
     // SSS Displacement Strength setting
     var m , n;
     for ( n = 0 ; n < materialList.length ; n++ ) {
      var nProp = materialList[ n ].getNumProperties();
      if ( for m = 0 ; m < nProp ; m++ ) {
       // Is the property hidden?
       if ( ! materialList[ n ].getProperty[ m ].isHidden() && materialList[ n ].getProperty[ m ].inherits( "DzFloatProperty" ) {
        materialList[ n ].getProperty[ m ].setValue( materialList[ n ].getProperty[ m ].getDefaultValue() );
    }[/code[
    instead of its original zeroing procedure (I haven't checked that for functionality - and you'd need to handle other property types yourself in an analogous manner)
  • Yonas AngYonas Ang Posts: 108
    http://ovbi.org/~rhaseltine/data/ZeroDisplacementLimits.zip
    Thank you very much Richard, this surely come in play when you have many SSS surface and some with displacement some aren't
