Restore every... that's EVERY SINGLE SETTING (including content directory) to factory resets
Hey folks!  Once again, I am having issues reinstalling all my content into my D drive correctly (There are three... count them THREE actions and paths you must put your settings to correctly, which I am not doing properly)  So I want to TOTALLY restore EVERY single setting I have changed back to the beginning so I can use some of the tutorials that MAY or MAY NOT help (depending on which version).
Now... that being said, what I REALLY need to do is, reset ALL my settings to default.  BEFORE anyone suggests that I uninstall and reinstall, I've already done that three times and the new pathway settings are still the same (and possibly incorrect) I need someone who knows how to reset all my DAZ studio settings to factory default and please, I beg you,  do NOT tell me  Edit>reset" because AS of DAZ Studio 4.10 (as seen in the screenshot below) that is NO LONGER AN OPTION (So please don't suggest it)
Now, if anyone WANTS to explain how to correctly repair ALL the pathways to move my library from C drive to D drive, I've also included screenshots from my DAZ studio AND DIM so you can educate me and help teach how to move everything CORRECTLY... and remember, this is DAZ Studio 4.10... THAT'S 4.10 so adjust your knowledge for a new version which MAY have changed the settings and therefore the way it functions.
  • fastbike1fastbike1 Posts: 4,079
    For starters, you shouldn’t have “content” in the path. DIM installs everything below the Content folder..
  • Richard HaseltineRichard Haseltine Posts: 108,453
    You need to add the Content folder to the end of the path for Daz Studio Formats in Content Directory Manager, they should all match.
    Remove the D: paths in the Applications tab.  Those pointer are for where the app is installed and have no bearing on content.
