Mysterious log warnings when loading Genesis
barbultbarbult Posts: 26,424
I see strange warning messages in the DS 4.6.0.18 log when I load Genesis. Does this mean my Mavka, Andrei, and Julie characters are not working correctly?
Mavka warnings reference Hitomi moprphs, but Hitomi is not listed as a prerequisite for Mavka for Genesis.
Andrei warning references a Hitomi morph, but it seems unlikely that Andrei for Freak5 requires Hitomi??? The product page doesn't say so.
Julie warnings reference FhMJulieHead.dsf, which I have in the folder path referenced.
I don't really know how to interpret these warning messages. This is what I see in the log file when I load the basic Genesis figure:
WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/Mallenlane/Hitomi/PHMEarsElfClassic.dsf#PHMEarsElfClassic?value in file : /data/DAZ 3D/Genesis/Base/Morphs/smay/Mavka/MCMMavkaHdEarsElfClassic.dsf
WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/Mallenlane/Hitomi/PHMEarsElfAnime.dsf#PHMEarsElfAnime?value in file : /data/DAZ 3D/Genesis/Base/Morphs/smay/Mavka/MCMMavkaHdEarsElfAnime.dsf
WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/Mallenlane/Hitomi/PHMEarsElfClassic.dsf#PHMEarsElfClassic?value in file : /data/DAZ 3D/Genesis/Base/Morphs/smay/Mavka/MCMMavkaEarsElfClassic.dsf
WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/Mallenlane/Hitomi/PHMEarsElfAnime.dsf#PHMEarsElfAnime?value in file : /data/DAZ 3D/Genesis/Base/Morphs/smay/Mavka/MCMMavkaEarsElfAnime.dsf
WARNING: fileinput\dzassetdaz.cpp(5069): Could not find output property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/Mallenlane/Hitomi/PHMHitomiRealisticNose.dsf#PHMHitomiRealisticNose?value in file : /data/DAZ 3D/Genesis/Base/Morphs/Morris/Andrei/CTRLAndrei.dsf
WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/YoungTeens/FhMJulieHead.dsf#FhMJulieHead?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/YoungTeens/MCMJulieHdUpperEyeLidDownR.dsf
WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/YoungTeens/FhMJulieHead.dsf#FhMJulieHead?value in file : /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/YoungTeens/MCMJulieHdUpperEyeLidDownL.dsf
  • Richard HaseltineRichard Haseltine Posts: 108,934
    It means there are correction morphs, that make adjustments when both the listed morph you have and the morph you don't have are set. Since you don't have one of the morphs the links won't be created - if you did have them then the correction morphs would make the combination look better.
  • barbultbarbult Posts: 26,424
    Thank you, Richard. I won't worry about them then.
  • LindseyLindsey Posts: 2,009
    edited July 2013
    Opps.. comment removed.
    Post edited by Lindsey on
  • PantherTOPantherTO Posts: 0
    I was searching for something on a similar problem with Hiro 5. But While I understand Richard's answer in reference to the first part of the post. That references to Hitomi were missing. The above doesn't seem to be the case. Both warning are Julie related to Julie, not to some other content not installed. Those 2 warning look completely contained in the Julie product.
    Looks like I will have to read the errors carefully and try to figure out what its looking for. Though for the above, it looks like it is looking for itself.
