Looking for G8F Nurse Uniform, Doctor's coat or Lab Coat
dlm4001
in The Commons
I need a nurses uniform, doctor's outfit, or a lab coat that can be worn over another outfit for G8F. I tried autfitting some G3F Nurses uniforms and Lab Coat and it was not the quality I was looking for. (Distortions under the breast, that funky area in the front of the skirt that Smoothers rarely fix. )
Anyone know of a clinical looking outfit for G8F? (I have a G8F character I want to use, but if I have to, I will create another using G3F.
https://www.daz3d.com/catalogsearch/result/?q=doctor
Will bring up a couple. There are even a couple of $1.99 bargains for doctor & nurse but you need to use autofit & fit & refit to successfully newer generations of Genesis for them to fit Genesis 8. The style is a bit old fashioned though but it is still close to modern styles.
Don't use autofit with G3 clothing, just load it and edit the scene identification base to genesis 8 female/male and it will fit as normal
Yes and no. It will fit, but you may have to make some minor adjustments on any arm or leg positioning with the clothing. (This is less the case with tank tops and skimpwear that doesn't cover the legs). However that's not difficult at all. And there's a lot less distortion than with Autofit even so.
Thanks all. I skipped the autofit and set the Scene ID to G8F and it worked MUCH better. I used Fit Control to make a few minor adjustments. The G3F H&C Nurse uniform worked well.
