Looking for G8F Nurse Uniform, Doctor's coat or Lab Coat
dlm4001dlm4001 Posts: 205
I need a nurses uniform, doctor's outfit, or a lab coat that can be worn over another outfit for G8F.  I tried autfitting some G3F Nurses uniforms and Lab Coat and it was not the quality I was looking for. (Distortions under the breast, that funky area in the front of the skirt that Smoothers rarely fix. )
Anyone know of a clinical looking outfit for G8F?  (I have a G8F character I want to use, but if I have to, I will create another using G3F.
  • nonesuch00nonesuch00 Posts: 18,753
    https://www.daz3d.com/catalogsearch/result/?q=doctor
    Will bring up a couple. There are even a couple of $1.99 bargains for doctor & nurse but you need to use autofit & fit & refit to successfully newer generations of Genesis for them to fit Genesis 8. The style is a bit old fashioned though but it is still close to modern styles.
  • FSMCDesignsFSMCDesigns Posts: 12,844
    Don't use autofit with G3 clothing, just load it and edit the scene identification base to genesis 8 female/male and it will fit as normal
    954 x 663 - 250K
  • DaWaterRatDaWaterRat Posts: 2,885
    Yes and no.  It will fit, but you may have to make some minor adjustments on any arm or leg positioning with the clothing.  (This is less the case with tank tops and skimpwear that doesn't cover the legs).  However that's not difficult at all.  And there's a lot less distortion than with Autofit even so.
  • dlm4001dlm4001 Posts: 205
    Thanks all.  I skipped the autofit and set the Scene ID to G8F and it worked MUCH better. I used Fit Control to make a few minor adjustments. The G3F H&C Nurse uniform worked well.
