How do I load an asset without the required figure being in the scene?
FlortaleFlortale Posts: 611
edited June 2018 in The Commons
I'm new to DAZ. I'm trying to load an object from the left library window into the scene.
Post edited by Flortale on
  • FSMCDesignsFSMCDesigns Posts: 12,846
    Normally you can load any figure or object when the figure it depends on is not selected. If I remember correctly, NGV7 uses a script to match the texture from the figure it is applied to, hence the error message. If it is a geoshell, I don't know if you can load it as a prop.
  • FlortaleFlortale Posts: 611
    Thanks!
