How do I load an asset without the required figure being in the scene?
I'm new to DAZ. I'm trying to load an object from the left library window into the scene.
Post edited by Flortale on
Normally you can load any figure or object when the figure it depends on is not selected. If I remember correctly, NGV7 uses a script to match the texture from the figure it is applied to, hence the error message. If it is a geoshell, I don't know if you can load it as a prop.
Thanks!
