cloth is not moving with character
Hi all,
I got a problem with the "Morphing Business Suit ".
I applied the business suit to the genesis character and played with the morphs for a good outfit. But the problem is when I try to pose the character, cloth is not moving with the character.
Any help please..
Thanks,
Shilpa
It might be that the items have loaded without being fitted to Genesis. I've seen this happen when the Content Management Service was either off, or not functioning properly.
Select the item that's not moving properly and go to the Parameters pane. Under "Fit To..." make sure that "Genesis" is chosen (or you can right-click the item, choose "Fit To..." and then select Genesis). Hopefully that fixes things...
Keep in mind that some clothing items (usually things like dresses and long skirts) have movement morphs that you need to adjust in order to make sure that the clothing follows the character's movement, but that doesn't seem to be the main problem here.
