Flow chart spread sheet webpage for Genesis model versions
Dear Daz family, I'm new to the daz 3D community and I got several Pro packs when they were on special which includes animals/actors/anthropomorphic creatures like the lizard man, centaur and Minotaur along with Michael 4 Victoria 4 (their variance) and freak 4. I'm overwhelmed with trying to fit clothing and understanding the mechanics of all these conversions, UV mapping, converting,batching, skins,morphs and what not. Also a lot of the clothing I get doesn't seem to fit right on other characters and I'm not sure what I'm doing wrong. Perhaps I'm just not understanding the process. I was wondering if there was a flow chart available, for example, an M4 character might have an arrow pointing to what generation it is, followed by what converters/uv maps/batching/etc (with links to purchasable content) depending on your goal. The flowchart would eventually lead to the current Genesis, which I assume is the goal since it'll have more options available and flexibility. Would Following the flowchart in reverse allow you to change from a Genesis model back to the previous one? Would there be a reason to do so? If not a flow chart, how about a spreadsheet or a web page with drop-down menus that you select a model name or version and then it would list all that was said above. Is there anything of that nature available? A visual aid would be a big help here. Thank you for your time and any advice would be appreciated.
History of Daz Figures This does need updating but it takes you part way through
Compatibility Matrix ie what you can use with what. Again not up to date, but gives you some idea
