Millenium Dragon Blues
I can't add tectures to the dragon. I just have the green base color. Help. The whole thing is installed.
What have you tried? Your info is a bit vague.
Have you tried using the material presets in The Content Library, did you have the dragon selected? I have just been using this product and all works as it should.
I can make thjis more clear. I can do the the dragon's head ,but I am having doing his body. Any tips ? I try to do it and I flounder.
See this is the problem if you are using a preset to load the materials then it shouldn't just texture the head but load all the textures at once. This is why I ask how and what exactly you are doing to load the materials.
Step one go to the Content Library Pane (not the Smart Content Pane) and open Poser Formats > Name of your content folder ie; My Library > Figure > Mil Dragon and load a fresh copy.
2 Now open Poser Formats > Name of your content folder ie; My Library > Pose > Mat Mil Dragon and double click on one of the material presets while the dragon is selected.
Now if this is what you have already tried then A; you could have a corrupted download (it does happen but rare) or B: you didn't install it properly or C; the is a fault which Daz3D tech will have to deal with it via a support ticket from the Help menu at the top of this page or via the Bug logging site.
I did as you stated and the map did not completely fill the dragon.
You can seee the options I have .
Well if the third preset named "All Map Green" doesn't work then I would be contacting DAZ3D tech department via the Help menu above. As that is the preset that will apply all the texture maps to the Dragon ONLY.
Thanks, that is what I did.
Apparently I just loaded daz and the dragon and the skin map is loaded :):cheese:
Nice one thanks for letting me know. I was seriously scratching my head over this one.
